Thank you very much for your help!
I was googling the same stuff, but came across a rather interesting thread specificaly about my motherboard. Turns out this motherboard suffers from HUGE vdroop, (my new technical term for today, hehe) so I need to set higher voltages in the BIOS than per usual. I also found that the board doesn't fully support 1066mhz for the ram, so i've dropped mine down to 1000mhz, as advised in the thread.
I've set the following voltages:
Vcore: 1.4
HT: 1.44
NB: 1.44
SB: 1.6
As a result, i'v got the FSB up to 1600mhz (400 effectively) which is giving me 3.2ghz! Woohoo.
Here's some pics from CPU-Z. Notice the much lower Vcore voltage than what I've set in the BIOS:
One question here. Looking at the RAM timing. Is the Bank Cycle Time of 29 clocks normal? I've set the memory timings to 5-5-5-15-2 and left all the advanced timings on auto...
Here's a pic of the CPU temps on idle:
They're exactly the same as what they usually are with no OC'ing... Can anyone recommend me an app to get a good heat test done please? If that's all OK, I'll then have a crack at this Prime95 application for some proper testing. I just want to get all the basics sorted first.
Cheers!
Vcore: 1.4
HT: 1.44
NB: 1.44
SB: 1.6
Cheers!
