Personally speaking I would not go by the file size alone as this is trivial to duplicate, the MD5 hash is the only reliable way to check as this cannot be duplicated. I only included the file size in my post so people can very quickly weed out the obviously tampered iso's.![]()
Has anyone regsitered RC1 already? It came up last night trying to do it, but it failed.
Just make sure your PC can boot off a usb stick. Then mount the iso, and copy the files/folders from it over to the root of your usb stick. Then either run setup from the stick within windows, or just reboot and access the stick from there.Has anybody got a decent guide of how to install from an external USB drive, I've run out of DVD's and I want to try and install from an external drive.
HEADRAT
so if the hash matches then it is the 7100 is the official RC?
This leak is the official RC from someone close to Redmond. It will not change later. It is branded build 7100 and is a milestone build. When MS makes it available for download, it will match this build exactly...It does not have a feedback button because it is no longer considered beta. It is for your evaluation only just like the watermark indicates.
PotatoMan83 had mentioned that they were told that MSFT would be giving out new keys for RC, yet the beta1 keys are working. My answer is that MSFT decided to leave the beta1 algorithms in place to prevent the fiasco which occurred when they tried to limit the number keys and make them unique. That did not work so they finally gave in and gave out the multiple use keys. So, why go through that again, leave the existing keys working for the RC.
Well I hit my first hurdle - you can't upgrade from Windows XP. How bizarre. I thought that would be a given. I shall have to do a backup now.
I've followed a couple of guided but when I try and install I get:
File \window\system32\boot\winload.exe
Status: Oxc00000001
Info: The selected entry could not be loaded because the application is missing or corrupt.
HEADRAT
Can i just update from 7057 or do i have to do a fresh install?
How does one set all the files/folders to be the same view? I want them all to be medium icons but am having to do it in every folder : /
Cannot find the 'Apply to all folders/sub folders' option like on xp.
