In game CPU monitor
24 Mar 2006
UK
Are there any apps that display CPU usage onscreen during a game? Kinda like an FPS monitor but for processors.
I'm currently trying to work out what to upgrade first, mobo\cpu\ram or graphics card.
What about rivatuner, it can show all sorts of information, GPU and CPU. I redirect my OSD output to my G15 LCD, but you don't have to.
What's your spec? We can just tell you what to upgrade if you really need one and what games do you play?
If you want to know your cpu usage, why not alt tab and check windows task manager.
Rivatuner has an in game overlay and has a history graph.
You could hook up a cheap spare monitor and have taskmanager fullscreen on it when gaming :p.
The problem with that is cpu usage may well be very different when you are alt-tabbed; many games seem to pause automatically when they lose focus for example. OK so you can track history on the graph but you can't take a snapshot at a particular moment.
Unless you have 2 monitors, then taskman is ok :D.
But I know what you mean, CoH used 1.1gb when tabbed out, but when looking at it real time I've seen it to to 2gb easily, rising steadily, then when tabbing out: BAM, 1.1 gb again. Tabbing out is certainly not the way.
Also a lot of games simply are stuck on 1 or 2 full cores cpu usage when tabbed out.
