I recently bought a Zotac GTX 260 Amp! edition (55nm, 216 shaders) from OcUK. It was factory overclocked to 650 core, 1400 shaders and 2100 memory.
I had problems with it straight away, and originally posted for help Here ...Only read of you have too much time on your hands
I decided to RMA it to Overclockers and a few working days later I received the same card back because they couldn't find any errors. Included with the card was a report saying which tests they'd done and screenshots etc. They tested it with crysis benchmark, world in conflict, furmark, 3dmark06 and grid. The conclusion of the report was:
"There was no fault found. Please check your other hardware or software installation" and "No fault was found GFX card passed all tests. When testing with grid the 1.2 patch is required as without graphical corruptions appear."
I put the card back in my machine and had the same problems immediately.
So then I took some pics of the texture corruptions with my camera phone and made a post about the problem in the 'OcUK Customer Service' forum including the pics. I also stated in that post that with the card underclocked to default GTX 260 speeds the card works flawlessly. Here are the pics..
Call of Duty: World at War after 15-30 mins of play..
Grid (with v1.2 patch installed) after a few minutes of play..
Half Life 2 Ep2 after a few minutes of play..
Call of Duty 4 after approx 45 minutes of play..
I got a reply there saying it could be an issue with my power supply or a strange compatibility issue with another part of my system
Also raising my PCI-E frequency to 105 in the BIOS was suggested (which I tried and didn't make any difference).
My power supply is a brand new Be Quiet 750 Watt unit and my system is 100% stable and I never had any problems at all with my trusty 8800GTS 512.
I installed ATITools this afternoon as well and ran the artifact tester. I went off to make a cup of coffee and came back to a lot of beeping and this..
I just want to re-iterate here that these problems only occur when running the card at the factory overclocked speeds. When I underclock it to default GTX 260 speeds, there are no problems whatsoever.
Between sending the card back and being charged for testing and return postage I've spent an additional ~£28 on top of the price of the card.
Any ideas or suggestions will be most graciously welcomed.
Also raising my PCI-E frequency to 105 in the BIOS was suggested (which I tried and didn't make any difference).My power supply is a brand new Be Quiet 750 Watt unit and my system is 100% stable and I never had any problems at all with my trusty 8800GTS 512.
