AMD TriCore phenom Black 3.5ghz- new system- worth it?
27 Apr 2009
hi there, new to this forum and to 'extreme' PCs but i have recently found an offer on overclockers that offers this PC:
- AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz overclocked to 3.5GHz+!
- Gigabyte GA-MA790XT-UD4P (Socket AM3) PCI-Express DDR3 Motherboard
- Corsair 4GB DDR3 DHX 1600C9DHX Twin3X (2x2GB)
- 2x XFX ATI Radeon HD 4870 1024MB GDDR5 TV-Out/Dual DVI/HDMI Crossfire
- LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive
- 2x Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache in RAID0
- Corsair TX 650W ATX2.2 SLi Compliant Power Supply
- OCZ HydroFlow HF-MK1 CPU Waterblock
- TFC Xchanger - Single Radiator 120
- XSPC Dual 750 Bay Reservoir & Pump - Clear
- TFC Compression Fittings
- Black Tubing & Fluid
- Arctic Silver 5 Heatsink compound professionally hand installed by our technicians
- 1yr Onsite Collect & Return Warranty
Windows Vista Home premium 32bit
antec 900 2 case
all for £1413.98 inc VAT
i have about £1500 to spend but i cant really build my own at the moment, due to how im getting the funds, (nothing illegal honest :D)
but the main question is:
is the AMD tricore worth it? running at 3.5ghz OC'd, is there a similar-priced alternative with much more performance? surely that AMD chip isnt slow.
amongst home recording (music) and maybe a bit of video but not much i wanna be maxing out games at 1080 resolution, will i be able to do it for a good while with that tricore or should i think on?
any help gratefully received :D
thanks for your help
it's a nippy rig - but for the money I would consider i7
Its the sum of the all the parts that gets that figure.
I could spend £1000 just on a monitor.
Keeping everything as it & going i7 with equivalent motherboard will add at least £200 on top of the figure.
If you got the extra £200+ then think about it.
I would not sacrifice water cooling for anything.
Once you have had a complete & quiet water cooled set-up you don't want to go back.
thanks for that my man, thats what i was thinking.
a lot of home recording, guitars and vocals, going on as well so the quieter the better and water cooling will be much quieter than fans, right?;)
I would forget the water cooling (this will be a good chunk of price) and get I7 or get cheaper AMD
i dont have the money to spend on an i7 and keep the blu ray drive and water cooling, and 2 CF'd HD4870s will kick ass so i think i'll make do with the 3core AMD, its not exactly slow right?
you have one judging by your spec, what do you think?
thanks 4 your help :D
You will still need fans but you can have them turned down more.
I have a mixture of passive water cooling & rad and with the gfx cards cpu & motherboard components being water the case fans which are actually the rad fans are almost off until i start gaming & then any noise does not matter.
If i was not into over clocking the 2 passive Zalman Reserators would be more than enough.
Only the PSU can be heard & im thinking of maybe a Koolance USA-1300/UK-1700W Liquid-Cooled Power Supply.
Tri-Core Phenom at 3.5 definitely is not slow. They are nifty little things, but this is coming from a man who upgraded from a 2.0 3800x2....
I also had water cooling before but I don't think I set it up properly. It was just loud for me. Now I had a scythe ninja 2 and TRad2 for the 4870. Last night my idle temperatures for both were low 20's.
