Not one to go by most reviews, rumors and other people's opinions
I picked up a HD4890 to play with and it has impressed Me !
It runs very cool and I would say relatively quiet, under high load You get a "woosh" from the fan/cards exhaust but it's not a nasty "Jet type whine" like the old X850, 1800,1900 cards.
I have never had a problem with a little fan noise under heavy gaming but as this has a proper Fan curve and stays in the 60's under load with the Improved 4870 cooler ( extra internal heatpipe) You could easily run a fixed fan setting in CCC and reduce noise further and keep the card under 80c if required.
Seems ATI still can't find a way of changing DDR5 clocks without causing a little Screen flash so run the Memory at full speed all the time which is wasting lot's of power , I have a workaround by editing the bios as I did for the 4870 although this card runs driver controlled voltage regulators I have easily dropped 20+watts in the Desktop and the card idles at 46c
I played with Asus smart doc utility but although it will help anyone wanting heavy overclocks it seemed to do very little to reduce power off load.
So there You have it, If You liked the HD4870 Your going to love the HD4890
I would be interested to hear other owners thoughts
