I like the look of that.. custom program? Or can you make your own menus like that within windows?
right click the taskbar, toolbars, new toolbar. Then just have 2 folders of shortcuts somewhere and link to those.
I dont think all your apps have to be re-installed to work, I know allot of mine does not and all my stuff is almost as organised as you apart from the fact I dont organise in the crappy start menu, I have my own menu
I find the PC randomly wakes up sometimes, sleep function is broke still.
Could be windows updates or media center guide downloads - they're the usual culprits. XP and Vista used to wake me up at random hours of the night doing this too.I find the PC randomly wakes up sometimes, sleep function is broke still.
Yea I used to keep my PC in sleep all the time here when on Vista and it never woke up, after upgrading to Windows 7 that's not possible with the fans at 100%, even with the fans at 40% I cant sleep, any noise wakes me up![]()
Ah, not just my rig then. Cheers.
silly question,
How do you get RC ( i know you have to wait till the 5th) and then how do you install it?
Sorry never done anything like this before. But it looks so sexy i'm gonna give it a go.
(i did read most of the thread but could not see anything)
Download off a torrent site, google mini torrents, use the first result, RC is out now it's build 7100, install it either via upgrade or via clean install the same as you would with xp/vista but make sure you have a beta key to use.
Then check the Hash of the iso with the tool in the 1st post.
