- 7 Mar 2009
- Sheffield
Whats the best Surround Sound Headsets atm for gaming?
A normal proper stereo headset - Sennheiser 595s or similar.
I've had the medusa ones for years & they are quite good, wouldn't mind the razer barracuda or if I'm really flush the Megalodon.
. OCuk should probably address this because it's a little misleading.Just ordered the megalodons. I have always gone with cheap headsets before but I break them so fast I thought I'd get something worth taking care of. Pity they are not in stock atm... altho didn't realise this until I had finished order because it still let me select the next working day from the delivery calendar, so I naturally assumed it was in stock. OCuk should probably address this because it's a little misleading.
Correction. A normal stereo headset will only give a surround effect if it's fed a signal designed for surround over headphones.
For PC games, this means using either a game that does it natively (which are few and far between), a soundcard with surround virtualisation for headphones (e.g. Dolby Headphone or CMSS3D Headphone on Xonar or X-Fi) or a suitable reciever with surround virtualisation (e.g Dolby Headphone or Yamaha SilentCinema - the former is sometimes built into surround headsets).
You feed a stereo headset a stereo signal and it will give you stereo. It may give the illusion of soundstage but it can't add information about front, back or elevation that isn't there.
My personal preference would be a Xonar (for Dolby Headphone) plus a good set of stereo headphones.
It's fair enough to recommend the HD595s but the OP asked for surround sound headsets. The HD595s are stereo headphones. It is misleading to recommend them as surround headphones without clarifying the additional need for a suitable source (Edit: or an alternative mike for that matter).
Well it clearly states that it is on PRE ORDER.
Now if you researched the Megalodons, you would know that they aren't even released yet but will be in the next few weeks.
Jeez![]()
.Well it clearly states that it is on PRE ORDER.
Jeez![]()
