Monitor broken? 22" LG.
30 May 2008
Hey guys,
I bought a 22" LG monitor about 15 months ago which has been faultless.
However, last night i turned the pc on and nothing happened, so i turned the monitor off>on and it projected an image for about 0.5 of a second and then turned off again.
If i turn it off> on i can do this over and over.
My question is, is it worth getting it repaired and if so where could i get it repaired?
If not whats the best 22" replacement monitor for £150?
Thanks!
Gustov
p.s I 100% know its the monitor as its doing the same on my other pc.
Well I guess you have done what you can imho.
I'm on the search for a 22" myself so if you do find something a bit special keep me posted please :D I've been looking at the ASUS ones on OCuK (222H &226H), I had made my mind up to get a 226H but it's out of stock now.
That's the one I'be been thinking about as the 226H model is now gone.
Depends where you got the LG one from & what warranty was given with it, some have a 3 year warranty, worth a go anyway.
