Windows 7 on Bootcamp
Man of Honour
29 Jun 2004
Oxfordshire
Hey guys
As the title says really, has anyone tried this? Does it work alright?
I understand the drivers are the same as Vista pretty much so I'm assuming it should be ok. I'm sure you'll be able to tell me though
Cheers
I installed it and I installed the drivers and it seemed to be running in the normal low power mode not using the high end graphics so it may work as you say but I have a experiance of it not working.
Tempted to bootcamp my MacBook with the latest Win7 7100 build. Does anyone know if the touchpad works just as well in Win7 as OSX (gestures etc)?
If not I won't bother :D
thanks
Si
Running 7077 on my MBP for work (cough) and games, Steam mainly. Works fine, not had any trouble at all.
I've never had any issues with the two finger scroll? must admit that I use a mouse most of the time though!
