Will RADEON HD 4350 run BBC iPlayer HD?
What exactly is the issue with the iplayer ? It's not your graphics card as said.
Have you got the latest flash installed ?
Downloaded, not streamed obviously, HD stutters, all other playback on my 2MB speed is ok.
All latest gfx drivers and Flash.
Flash Beta is meant to use gfx hardware, not on mine yet though. Normal Flash doesn't work either.
As mentioned above... I found you need a connection capable of a good 4-4.5mbit sustained speeds to be able to stream iplayer HD content...
First check CPU load ( taskmanager) while playing back
If thats ok it's software/codec issue....end off ;)
Pretty much, try installing the K-Lite codec pack if you don't already have it.
I have an 8800GT and have zero issues with iPlayer HD. I'm using the 182.50 drivers.
