- 5 May 2009
Hi guys,
Just a bit of advice really. I've had my Mk1 for close to 7 years now and love it to bits. A friend of mine recently wrote his Mk1 off. Drivers side damage... front wheel took most of the impact. Bent suspension and scuffed all the panels down that side.
The car itself is a 1.8, lowered, roll bar hoops, Super Drager exhaust full system including a manifold that looks like a work of art!, boot spoiler etc
Now to the question, do you guys think it's worth buying and putting the above bits to mine? Mines a 1.6 and was possibly thinking of even transplanting the 1.8 in mine along with the brakes etc. The manifold won't fit a 1.6 so would have to drop the whole engine.
Thing is my 1.6 had done 100,000 but is such a sweet little engine and still feels like it has loads of life. The 1.8 has done 80k and again feels very healthy.
So... worth doing or do you think its more hassle that its worth? He wants £300 for his car.
Cheers!
Cheers!
Flog the exhaust on and buy a nicer one for your car with the proceeds. I'm just not sure its worth all the hassle of an engine swap for the upgrade. I would be tempted to flog off everything apart from the brakes and then use the money to buy some better suspension + exhaust for your 1.6 Then when thats done you can perhaps look towards a turbo for the 1.6 if you crave more power.
