It passed ok in March.
Well actually it failed on a 35% brake imbalance, but once that was fixed it passed ok.
As for the OPs question. I think part of it comes down to how much you're prepared to work on the car yourself. If you're happy doing work on cars then get an old Ford, it may break more often, but the parts are cheap. If you're going to be paying a mechanic for everything, then a Toyota or Honda is probably a better bet because they'll break less often and the more expensive parts wont count for much once you add in the labour charges.
It's a shame you can't stretch the budget a little. With the 2K scrappage scheme on that Golf, you could probably get yourself a brand new Kia Grotbox with a 7 year warranty and then you just need to worry about the costs on the servicing schedule.
