Grounding yourself before handling components?
Takes about a second to ground yourself, so why not? I'd be kicking myself if I'd just blown a couple of hundred quids worth of kit for the sake of touching the case once.
I have always been really paranoid about this...
Even to this day, anytime I am messing around inside my case, or when I am doing a build I always touch a nearby radiator before I go to touch any components...
i started off touching a radiator pipe - I now use the plugged in PSU method as it's less mileage.
When i did my first build about *cough* 15 *cough* years ago, information on how to do this was very thin on the ground but the one common theme i kept coming across was grounding yourself at regular intervals. During that first 'PII' build i must have got up about 200 times to touch the radiator pipe. I was actually physically knackered after the build as much due to stress and physical exersion.
That build pretty much gave me an ocd condition specific to grounding myself on builds even though i'm actually pretty neutral about the whole grounding issue. It's now become more of a superstitious ritual than a means of dispelling an electrical charge.
I'm sure my wife thinks i'm a loon when she watches me build a pc - i've explained the theory behind it but it doesn't stop you from feeling a numnut as you bend down and touch a radiator pipe for the umpteenth time and then trot back to the table to position a component.
My rigs run on the 'sods-law' principle and as such i try to minimise any possible problems during a build - so if plugging a psu, or touching a rad pipe reduces 'sods-law', no matter how uneccessary it may be, i do it.
Each to his own though - do what works for you.
I've never bothered beyond touching something earthed, either a radiator pipe or the PSU (plugged in but not turned on) and to the best of my knowledge I've never damaged a PC through static.
That's not clever, you'll only get a inch or two to move :P Lol
It does indeed produce a sticky situation. But at least it saves cumming and going all over the place to radiators and such. It is a little hard getting used to, but it soon becomes quite an easy back and forth task.
I'll get my coat.
+1 for the Radiator method...
On a serious note I do touch the radiator before I start and touch it everytime I shift my feet about just to be safe
