One issue Whappers - if they tie over the 2 matches (say 3-1 then 1-3) how will they settle it, since FIFA wont go into ET and penalties automatically?
Only fair way I can quickly think of is a third match with the subsequent ET and penalties. Also in each normal match I guess ET and penalties is now ignored (or is it just penalties?)...
Regards the 4 star team approach - best to allow duplications of teams as it kills off competition if people are playing teams they dont want to...
ps3ud0![]()
Fair points. Ok, to sum up, we shall have two matches for the Second Round and the Third Round. No Extra Time and No Penalties at the end of either Leg. If scores are all tied after two Legs then a Third Match is played. Sorted?
Ok, OP has been updated and hopefully there will not be any misunderstandings. For those who can't be arsed clicking the first page!
**Rule Change For 2nd & 3rd Round**:
1. Two Matches must be played
2. No Extra Time and No Penalties at the end of either Leg.
3. Away goals do not count. The most goals over 2 matches wins.
4. If the aggregate score is tied after Two Matches then a Third and Final Match is played to decide who goes through. Original rules as played in the First Round (i.e. Extra Time and Penalties if all tied at the end of the end of Normal Time) apply for the Third and Final Match of the Round (Should this happen to any of you!
