I'd try 195/50/15, although it's getting quite hard to find decent tyres in this size now. It's causing me trouble trying to get quality rubber for my Integra![]()
The Continentals come out at £66 a corner fitted which isn't too steep methinks.
I don't think Muffin is looking for performance tyres on his Megane. You're talking about performance tyres for track/spirited road driving. Whereas I think Muffin needs his tyres for daily normal useage.
I see the TR1's at £30 now on camskill so £75 for two delivered
how much is a tyre fitting in reality to obv include blancing? £15 for two tyres?
Also if theres 195/50/15 on the front and 185/55/15 on the back, will there be an issue?
..when your speedo reads 70mph, you're actually travelling at 68.99mph
