- 24 Nov 2002
- Abertawe, Cymru.
You have to assign the drive a letter in disk management in the control panel, it does the same on my rig to.
Drivers installed for the controller to which the games drive is attached?
I installed Windows 7 last night and I love the look and feel of it but I'm going to have to revert back to good ol' XP because my games run really sluggish. It's probably down to the fact I only have 2GB of RAM tbh.
I'm quite gutted that it didin't work out for me :/
Sluggish? Smooth but lower framerates, or stuttering?
Try disabling a few 'features'. Windows Defender real-time scan, auto defrag, Indexing, SuperFetch e.t.c.
Do some before and after 3DMark runs for consistency.
Maybe graphics drivers then. The beta ones I've been getting from nVidia (via Windows Update) haven't always been an improvement on the previous one.It was stuttering. When loading up a game it would start off fine but after about 20 seconds of moving around it would become quite stuttery and the camera movement felt like you were underwater, as though there was some resistance there.
how do you get a serial key for it?
You read this thread.
If I am going to make a fresh installation of the RC version on the same partition I have the BETA version, should I first try and format the partition (which I have tried but it telling me its in use, so can't format it?!?) or can I just start the installation and when it tells me that it will create a folder called windows.old just continue and later just delete the windows.old folder.. would that work or should I do it some other way?!?
Any and all help would be greatly appreciated since I would love to have it all done before 3pm!![]()
Are you trying to install the Windows 7 Release Candidate from within Windows?
Nope, I restarted the computer with the disc and did it that way.. got as far as picking where to ahve it installed and when I choose the partition where I have the BETA version it told me that it contains windows drives (or something along those lines) and would create a windows.old folder.. I was not sure if I should proceed or not so aborted it..
