I had trouble sticking them in the 1st time because i would always blink just before they were in.
That reflex has gone now and can stick them in quickly and effortlessly.
Only problem i have is i can never tell if they are inside out or not.
If they're in inside out your vision won't be as good, they'll be more prone to popping out and won't be as comfortable. The best way to tell is by the shape of the lens before you put it in your eye. If it looks perfectly round along the edge then its right, if its slightly curling over then its inside out and needs reversing. Took me ages to work that one out!
