PC making me feel sick
Status
Not open for further replies.
13 Mar 2009
Hi I have a real problem, when I use my pc it makes me feel sick, gives me kind of stomach pain. I think it's the fans.
Whenever I use my xbox 360 i get the same problem, like a burning pain in my stomach.
Is there a name for this? Anyone else get this?
Seriously within half an hour of me using the pc my stomach starts rumbling and gets painful. I have the HAF 932 case. I think I might have to open it up and turn off some of the fans to see if that helps.
what are the fans doing? do you have them sat on your stomach chomping away at your flesh?
the pitch of the sound pc fans produce isnt low enough to cause body disturbances.
sounds like youve got 1 of 4 things
-you play on your pc/360 so much you forget to eat and are hungry
-general illness at this time
-youre a hypocondriac
-you have swine flu
get your eyes tested and try a higher refresh rate as well as siting correct distance from display. It's usually just gives people headaches but I suppose it cold make you feel sick.
or this
Hypochondriasis
why would the fans make you feel sick? how do you even think of that?
-you have swine flu
LMFAO :D
Sounds like worms to me do you need to poo a lot or have an itchy bum ?
Stop eating whilst slouching (ie. whilst playing games) and you'll stop giving yourself indigestion. ;)
It's not the screen I have been using that for ages. I don't know what it is but its's something in that base unit, within half an hour of turning it on I start to get a stomach ache and if I leave it on it gets worse. Fumes?? I was thinking it was something to do with the fans and all the dust inside??
I might have to sell it if this continues.
seriously have you had your eyes tested recently? could be eye strain leading to migrain/sickness.
that made tea come out of my nose you bugger.. :D
Status
