OCZ Blade Series 4GB DDR2 1066MHz Low Voltage Now Available
9 Nov 2003
Leeds
Interesting part some of you might be waiting for here. :)
OCZ Blade Series 4GB (2x2GB) DDR2 PC2-8500C5 Low Voltage Dual Channel
OCZ Blade 4GB Low Voltage DDR2 OCZ Blade 4GB Low Voltage DDR2 available now. At only £50.99 inc VAT the OCZ Blade Series 4GB (2x2GB) DDR2 PC2-8500C5 Low Voltage Dual Channel memory offers greater overclocking potential than other 1066MHz kits thanks to only requiring 1.80 volts to run at the low timings of 5-5-5-18.
7 May 2006
London, Ealing
19 Dec 2003
Grimsby, UK
Gents
If you are looking for 1333 ram go ddr3 and run 5-5-5-18 as its faster :) and yes I know that means changing your motherboard.
I actually think this is the best post..8GB 1066 1.65V with DDR2...just killer :)
http://www.xtremesystems.org/forums/showpost.php?p=3782925&postcount=90
I'm guessing thats the new AMD edition kits thats coming out?
I made a request for OcUK to stock it about a week ago, hope it gets in soon.
Part Numbers: 4GB (2x2048MB) D/C Kit PN - OCZ3P1600LVAM4GK
LINK: http://www.ocztechnology.com/products/memory/ocz_ddr3_pc3_12800_platinum_amd_edition
Specifications
  • 1600MHz DDR3
  • CL 7-7-7-24
  • (CAS-TRCD-TRP-TRAS)
  • Available in 4GB D/C kits
  • Unbuffered
  • Platinum Z3 XTC Heatspreader*
  • AMD AM3 DDR3 Platforms Only
  • Lifetime Warranty
  • 1.65Volts
  • 240 Pin DIMM
8 Oct 2008
1333 5-5-5-24 1T can be hard to do ddr3, some IC's do it some don't. My point was people looking for DDr2 to do 1333 would do better going DDR3 as its a LOT easier with less juice, you just meed the right IC's.
The Blades are now being binned for speeds, we have 1066, 1150 and 1200, on the website. I still feel the 1066 will clock like crazy but you may need to raise voltage to 1.85 or so. Note I did NOT say 2V or anything stupidly higher, tiny jumps with these is all it takes...going from 1.82 to 1.83 may get you from unstable to stable.
28 May 2004
The US of A
Alright my curiosity is peaked... What would this ram do for my setup? An extra 100, 200, 300mhz? Will it drop temps in my system? Is it worth while to upgrade my current sticks to these?
Man of Honour
13 Oct 2006
I just bought some of the 1150 stuff - if the PCB is indeed black I will be very happy. Green PCB is so 90s :p
18 Feb 2009
Cambridge
would having 4 of these in a 8gb set up.
A) provide any kind of increase perfomance in multitasking, over 4x1gb
B) hinder any kind of overclock. (not extreme overclocking)
Man of Honour
13 Oct 2006
yay - mine have black PCBs and look far nicer than the pictures of them online - even better than the pics verbal posted...
Just giving them a memtest atm - went straight in at rated settings and booted to BIOS fine which was a suprise as this motherboard isn't the best known for its RAM support.
