Prayer's Answered? Western Digital HD TV
Question;
I own a WD HDTV and a WD Book 1TB drive. I am a little frustrated that it does not power down the hard drive. I physically have to unplug the USB cable. Now the HDTV I power off with the remote. Does anyone keep the drive permanently plugged in and powered on? Is there any cause for dataloss etc if it is left on? Overheating? Also should I be ejecting the drive first before unplugging?
Question;
I think if you were using a Portable drive which uses what its pugged into for power it'd turn off. The fact its plugged into the wall will keep putting power through it unfortunately! Afaik anyway. And you should eject, but i've had no data loss just unplugging.
My Western Digital book does not light up when just plugged into the mains. There is no on/off switch. It fires up the moment it gets plugged into the WD HDTV and teh lights remain on until I unplug it from teh WD HDTV. A lot of people have said it does nto power down teh USB sockets when its switched off. Does that make sense?
Are there any updates for it that will place MKV files with DTS encoding. Quite annoying, or alternatively any easy way to convert them to AC3?
Apart from that niggle and the fact it doesn't play DV Uncompressed AVI files it's really quite a bloody good little gadget. Top draw.
I have got a little utility Popcorn MKV Audioconverter. Takes 10 mins to do a movie and is really easy to use, did not even need to use instructions.
EDIT: You can batch convert as well, so just chuck a folder at it with all your DTS content and it will do them one by one
http://www.videohelp.com/tools/PopCorn_MKV_AudioConverter
If you'd read the rest of the thread I've quite clearly stated before that it will play MKV with DTS, however it sends the bitstream to the optical digital connection. It won't downmix DTS to 2.0 and send to your TV.
Buy an AV receiver or convert the files as advised above.
Do you mean it powers down your hard drive when you switch of the WD HDTV??
sorry taken me so long to get back....
yes, when i turn off the WDTV it first turns off the external hard drive and then shuts itself down. Im using a mains powered external hard disc rather then a usb powered one which i suppose could make a difference
Sorry, my bad it has been a while since I first made this thread. I remember people saying you can play DTS using the opitcal out I just wondered if since then any firmware had come out enabling playback of DTS audio.
Thank you very much mate.
Do I need to "Downmix to Sterio" the DTS files or will the WD HD TV do this anyway from AC3?
Cheers
It does play back DTS audio, just doesn't downmix to ordinary stereo. Not uncommon - most DVD players won't either.
'There’s no limit to the size of your media collection; just add more drives for more movies'
Only one USB port so isnt this out of the question?
Why would it be any better than connecting my laptop to the tv and playing off my portable drive like i do now?
Nope - two.
The WDTV is a lot less faff and a lot less mess.
You can use a usb hub and get an extra 4 HDDs plugged in. One guy on AVS has 4 external's plugged in, 4TB. All in sync and merged on the library.
If you are happy having your laptop plugged into the TV then don't invest in this little beauty.
It's bloody brilliant. Honestly haven't been so impressed with a gadget for ages. I thought there must be a catch for the price, but the video quality is incredible and playback is flawless. Just been sitting with a mate watching a World Cup Goals dvd I ripped years ago but got lost into the depths of my external hard drive. Absolutely fantastic gadget. 1080p is easily on par with Blu-Ray, certainly on my TV.
