A mincey question for the cooks
20 Sep 2003
Scotland
I have just come in from work and was gonna make some spag bol. I have some mince in the frifge that came out of my freezer about 3 days ago. It's been in the freezer for ages though as the use by date is April, which i think might even be last years April.
Will this be safe to eat?
Open the bag, you'll probably be able to smell if it's off. If you can't straight away, you will when you start cooking.
Beef should be fine for 5 days after getting out of the freezer (aslong as it was pretty fresh when frozen), so should be ok.
Smell it, if it smells ok, cook it, if not bin it.
After cooking it, taste it. If it tastes ok, eat it, if not bin it.
:D
Just opened the packet and the stuff smells fine, well no smell at all so I am off to make my dinner :)
As has been said, smell it, if it smells stale/sour then it's no good. And as cactuscake says, brown mince can be fine (it can go brown just by being in contact with the bag).
I thought it was 3 months for meat/poultry?
guidelines for idiots. Same as sell by/use by dates.
I don't know anyone who has got ill from frozen meat that are years old.
same as, who knows anyone who has gotten ill from rice spores from heating up a takeaway the next day. I eat rice 2 or 3 days old.
+1
Either that or we have cast iron stomachs :P
I'd be very surprised if the average house hold freezer can keep meat for over a year. if, in this case, the meat is good - it would be from this year, not last.
From the us goverment website
Does Freezing Destroy Bacteria & Parasites?
Freezing to 0 °F inactivates any microbes -- bacteria, yeasts and molds - - present in food. Once thawed, however, these microbes can again become active, multiplying under the right conditions to levels that can lead to foodborne illness. Since they will then grow at about the same rate as microorganisms on fresh food, you must handle thawed items as you would any perishable food.
Trichina and other parasites can be destroyed by sub-zero freezing temperatures. However, very strict government-supervised conditions must be met. It is not recommended to rely on home freezing to destroy trichina. Thorough cooking will destroy all parasites.
Length of Time
Because freezing keeps food safe almost indefinitely, recommended storage times are for quality only. Refer to the freezer storage chart at the end of this document, which lists optimum freezing times for best quality.
If a food is not listed on the chart, you may determine its quality after defrosting. First check the odor. Some foods will develop a rancid or off odor when frozen too long and should be discarded. Some may not look picture perfect or be of high enough quality to serve alone but may be edible; use them to make soups or stews. Cook raw food and if you like the taste and texture, use it.
0 f is -18 degrees.
