virgin media 50 meg world of warcraft hell.
28 Nov 2004
just had virgin media 50 me gline installed. was on there 10 meg line for 3 months. then upgraded to 50 meg.
problem is since going with virgin i cant play world of warcraft without disconections every 20 mins or so. used without my router firewall and used on 3 different opperating systems. problem still there. does any1 know what it is. :(
Well either your connection is dropping a lot or theres some other kind of problem :/
ping www.google.co.uk -t from your command prompt :P leave it going till you get disconnected from wow and see if it starts timing out?
If theres any problems there youre better off calling Virgin :P and if you dont see a problem... well call them anyway :\
IIRC I saw a thread like this a few days ago on another forum, and it turned out a lot of people where having problems on different ISP's, with the common thing being the Talia(?) backbone dropping packets or something similar.
Try doing a trace route to the WoW servers on a continuous ping for a few minutes, that should show if there is packet loss, and where it starts.
20 minutes is an odd timing thing for it to be directly ISP related, although I have experienced a real fun time in the past with WoW when my brother played it - his connection would effectively go dead after a few minutes due to what turned out to be a router issue (the WoW servers really didn't like the then current firmware that controlled the WAN port on certain Linksys routers*) - at the time the only way to sort it was to use a completely different router, or connect to the modem directly.
*IIRC it was an issue with the Broadcom chip's driver that was in the router firmware doing something the WoW servers didn't like.
hi and thx for the info tried what u said. after 14 mins playing game disconected me. and the ping timed out @ www.google.co.uk @ same time. what would u recomend me to do . thx in responce.
Post to newsgroup virginmedia.support.broadband.cable, seems to be some on the ball tech. support guys over there.
