How do you slam dunk and do other special shots in NBA 2009 on PS3?
4 Nov 2002
England - Leeds
Hi there, can you please tell me what to press to slam dunk or how you do it and other special moves in NBA 2009 on PS3, because I downloaded the demo and I cant work it out, doesnt say in the controls menu,
Thanks in advance,
SkScotchegg:D
Well I clicked on your link and thats very funny, but even after checking out all the websites in that search I still didnt find an answer. I already searched before I posted here which is why I posted, but you presumed I didnt try before I posted which was wrong.
I'd always search on yahoo before posting.
So can anyone tell me what button to press or how you slam dunk, thats all I want to know, how do we slam dunk in NBA 2009 ?
Thanks in advance,
SkScotchegg:confused:
That works when it actually gives real results. So you may have a fail from me :)
Anyways, here's a list i found.
for ps3 substitute:
L2=LT
R2=RT
L1=LB
R2=RB
square=X
triangle=Y
circle=B
X=A
***SHOOTING***
-Bank shot
Pull and Hold LT and move the RS (or press X) to direct the ball towards the backboard for a bank shot. The player will only use bank shots from within proper angles to the basket.
-Layup
When dribbling towards the basket, move the RS either to the left or the right side of the basket.
-Floater
when dribbling towards the basket, move the RS away from the basket to throw a floater.
-Reverse Layup
When dribbling towards the basket along the baseline, you can reform a reverse layup by moving the RS toward the baseline direction.
-Reverse Dunk
While dribbling towards the basket, pull and hold RT and move the RS away from the basket.
***SHOT STICK EXTREME***
-Changing Shot
You can change your shot while in midair to avoid a potential block. while the player is in the air to preform a dunk or layup, quickly move the RS in any direction to change your shot.
***ISOMOTION***
-Crossover
Pull and hold RT and quickly move the LS towards the opposite ball hand to perform a Crossover. For example, with th ball in the right hand, quickly move the LS toward the player's left hand.
-Double Cross
Pull and hold RT and quickly move the LS towards the opposite ball hand and then back to the ball hand direction.
-In & Out
Pull and hold RT + LT and quickly move the LS towards the opposite ball hand and then back to the ball hand direction.
-Half Spin
Pull and hold LT + RT, nd move the LS toward the player's facing direction. Then quickly move the LS to the opposite direction.
-Spin
Pull and hold RT, and rotate the LS in a half-circle starting from the ball hand to the opposite hand (going around the player' back).
-Behind the Back
Pull and hold LT + RT, and rotate the LS in a half-circle starting from the ball hand to the opposite hand (going around player's back).
-Sizeup
While standing, pull and release LT to perform a Sizeup move.
-Stutter
While standing, pull and release RT to perform a Stutter move.
-Quick Hesitation
Same as stutter just moving.
-Hesitation Drive
Same as Quick Hesitation just driving to the basket.
-Hesitation Cross
While moving, pull and release RT and quickly move the LS towards the opposite ball hand.
-Stepback
While moving, pull and hold RT, and quickly move the LS in the opposite direction of the player's movement.
-Stop & Go
While moving, pull and hold RT, and quickly move the LS in the opposite direction of the player's movement. Then, move the LS in the initial direction that the player was moving.
-Hop Step
While moving to the basket press Y.
-Hop Step Spin
While moving towards the basket, pull and hold RT, and then press Y.
-Hop Step Away
While moving towards the basket, quickly move the LS to the opposite direction and press Y.
***TRIPLE THREAT***
-Protect Ball
With the ball and an unused dribble, pull nd hold LT + RT and move the LS opposite the player's facing direction.
-Jab Step
Same as Protect Ball but move LS toward the player's facing direction. You can Jab Step in various directions away from the pivot foot.
-Launch Left/Right
With the ball and an unused dribble, pull and hold RT and move the LS to either left or the right side. You can also use either Jab Step or Protect Ball to set up the launch moves and fake out your defender.
-Spin Launch
with the ball and an unused dribble, enter the Protect Ball stance. Pull and hold RT and move the LS opposite the player's facing direction to perform a spin.
***POST OFFENSE***
-Post Up
Pull and hold LT, then move towards the defender to post him up.
-Faceup
Post up a defender by pulling LT, While holding the ball, move the LS away from the defender.
-Hold Ball High
Post up a defender by pulling LT, While holding the ball, move the LS towardes the defender.
-Shoulder Fake
Post up a defender by pulling LT, While holding the ball, move the LS to the left or right of the defender.
-Pump Fake
Post up a defender by pulling LT, While dribbling or holding the ball, tap X or quickly move the RS in any direction. If no pivot foot has been established, you can Pump Fake to either right or left side by quickly moving the RS to the left or the right side of your player, or move the LS to the left or the right side of youe player and tap X.
-Hop Step
Post up a defender by pulling LT, While dribbling or holding the ball, press Y to perform a Hop Step.
-Dropstep
Post up a defender by pulling LT, While dribbling or holding the ball, release LT and move the LS to either the left or right side of the direction the player is facing.
-Spin
Post up a defender by pulling LT, While dribbling or holding the ball with an unused dribble, pull and hold RT and move the LS towards the opposite direction your player is currently facing.
-Pump Fake to Hop Step
Post up a defender by pulling LT, While holding the ball with an unused dribble, tap X or quickly move the RSin any direction to Pump Fake. Once the Pump Fake starts, tap Y to follow up with a Hop Step.
-Pump Fake to Hop Step Spin
Post up a defender by pulling LT, While holding the ball with an unused dribble, tap X or quickly move the RS in any Direction to Pump Fake.Once the Pump Fake starts, pull and hold RT and tap Y to follow up with a Hop Step Spin. Only players with a high Post rating (OPOSY) can perform this move. Lower rated players will perform a regular Hop Step.
-Pump Fake to Hop Step Spin (opposite side)
Same as above but once the Pump Fake starts, move the LS to the direction behind the player and tap Y to follow up with a Hop step spin. Only players with a high (OPOST) can do this.
-Pump Fake to Drive
Post up a defender by pulling LT, While holding the ball with an unused dribble, tap X or quickly move the RS in any direction to Pump Fake. Once the Pump Fake starts, release LT, pull and hold RT and move the LS towards the basket for the drive.
-Faceup Jumpshot
Post up a defender by pulling LT, While holding the ball, move the LS away from the defender to Faceup. Once the Faceup starts, press X or move the RS down and release for the jumpshot.
-Post Package Shot - Hook
Post up a defender by pulling LT, Move the RS towards the basket to perform a Hook Shot.
-Post Package Shot - Fadeaway
Post up a defender by pulling LT, Move the RS away from the basket to perform a Fadeaway.
-Post Package Shot - Roll Left
Post up a defender by pulling LT, Move the RS to the left of the player's facing direction.
-Post Package Shot - Roll Right
Post up a defender by pulling LT, Move the RS to the right of the player's facing direction.
-Up and Under (Shot Stick)
Post up a defender by pulling LT, While holding the ball, move the RS to either left or the right side of your player to initiate a Pump Fake. Once the Pump Fake starts, quickly move the RS to either left or right, towards the basket, or away from the basket to follow though with th shot. Different Up and Under moves can be performed by moving the RS in various directions after the Pump Fake.
-Up and Under (Button)
Post up a defender by pulling LT. While dribbling or holding the ball, tap X to initiate a Pump Fake. Once the Pump Fake starts, move the RS to either left or right, towards the basket, or away from the basket and then press X to follow through with the shot.
***OFF-BALL CONTROL - DEFENSE***
-Post - Fight Off
When playing off- ball defense in the post and being backed down, move the LS towards the offensive player to attempt to push him away from the basket or to prevent him from gaining a position. The effectiveness of this depends on post ratings and weight differences of both players.
-Post - (Steal (onball)
While playing on-ball defense in the post, press X to attempt a steal. You have a higher chance of success if it is timed correctly when the offensive player initiates a post move or shot.
