Hi,
This thread is really a continuation of the one I started here a few weeks ago. I was quite content with a clock of 3.4GHz @ 1.2000V in the BIOS, but I got a little curious as to whether I could initially boot into Windows at a higher clock and then see if it was at all stable. So I've upped the FSB to 424 to give 3.6GHz and it booted into Windows with no problems. I then decided to do 15 runs of Intel Burn Test (is that excessive?) and its passed with no problems at all.
Core voltage was at 1.192V whilst under load. Temps were 69-69-68-65 so fairly toasty but they shouldn't get anywhere near that in day to day use. I shall probably run Prime 95 blend overnight just to make sure its totally stable but I'm guessing it should be ok if it can pass IBT?
