PunkBuster causing CoD4 to lockup
7 Dec 2008
Brighton
Hey people Ive been trying to figure out why I have been locking up in CoD4, run Memtest several times, updated BIOS u name it.
Finally narrowed it down to PunkBuster as the game works fine in SinglePlayer and in MultiPlayer servers with PB disabled. Lockups occur at random and leaves my PC completely unresponsive forcing me to hard reboot.
Ive uninstalled and reinstalled CoD4 + PB, followed by a format and installation of pretty much every chipset driver off the Asus website, all with no avail.
Does anyone know what may be upsetting PB here? At the moment Ive had to play on servers with PB disabled which aint as good for obvious reasons :(
Chris
Ive already manually updated PB to the latest, also disabled Windows Firewall and forwarded router ports for PB(PnkBstrA.exe, PnkBstrB.exe).
No error message just a system lockup, I dont get booted from servers because of PB so as far as I know PB is working fine. Ive checked Event Viewer but couldnt see much related to CoD4 or PB.
Intel Core i7 920
Asus P6T X58
3GB Corsair Dominator 1600MHz DDR3
Western Digital 640GB Caviar Black
Sapphire Radeon HD 4870 1GB (Catalyst 9.4)
SoundBlaster X-Fi Titanium (Driver 2.17.0006)
be quiet! 850W Dark Power Pro
XP 32-bit SP3
Nothing overclocked
Nope its a new build so decided to test it out with CoD4 and from what I remember Ive had this problem ever since I first installed. Other games like Left 4 Dead and Crysis work fine.
evenbalance.com said:
My computer locks up or "chugs" sometimes while I'm playing with PunkBuster Enabled, what can cause this?
PunkBuster "pushes" hardware and the Windows Operating System more than most software and uses functions in the Windows API (low level functions) that aren't used by most other programs. As such, there are a few cases where using PB can actually expose flaky hardware or other situations that don't cause problems for other software. Here are a few things that have helped other users make these problems get better or go away completely:
* Make sure you are using the latest version of PunkBuster (the latest version is always on our Download page) - also this link may help manually update your PB to the latest version when necessary
* From the game's main screen, press the tilde key (the ~ key) to bring down the console and enter the following line (without the quotes): "/pb_system 1".
* Never close other programs from your Windows Task Manager before playing the game, either leave them running or close them through the proper interface - killing a process doesn't always work completely even if it stops showing in the Task Manager and renegade threads seem to conflict with PB more than other programs that may be running in memory. There is a free utility that some players use called EndItAll to close all extra programs before they play to avoid software conflicts, crashes and lockups. You can get it from here.
* Check the add/remove programs list in your Control Panel and uninstall any programs that you don't use or that you don't know what they are.
* One program that seems to conflict with PB more than others is Norton Anti-Virus. If you have it installed, try uninstalling it to see if the lockups go away. Some players have reported that when this is the culprit, they can reinstall Norton Anti-Virus and the lockups don't come back.
* Other background programs that seem to conflict with PB for some users are Sound Blaster Live software and helper programs that come with video cards (especially ATI keyboard shortcut programs).
* Some players discovered that they had a computer virus and that the lockups vanished after it was fully removed.
* Experiment with the pb_sleep setting ... try setting it to 20, 250, or 500 to see if that affects your game performance. A few players have reported that all the problems go away when they "tweak" this setting.
* In extreme cases, a few users have reported that replacing their RAM (memory) or video/sound cards fixed the problem.
Ive tried all those with no luck either :(
Just noticed it says PB uses functions in Windows API, what does this mean? Ive also noticed PnkBstrA.exe and PnkBstrB.exe in my systems32 folder, could this be related?
I had the same issue, was because COD4 had issues with my onboard sound drivers. Had to either get a new sound card or motherboard, so I got the motherboard
I have exactly the same issue, and my computer locks up on both CoD2, CoD4 and CoD:WaW.
Would reinstalling sound drivers help? How would I go about doing that?
