Hi,
The last video card I bought was the 8800 GTS 512mb card. Up until then I knew what gen was what and what number suited each persons need.
However now I see 250, 260, 275 etc series and I don't know if the 2x is the same gen? If it is the same gen can someone explain which models are similar to what the 8800 was and which would be the lower end of the series ie thr 8600, 8200 etc was.
I hope this makes sense, I will try and explain a bit better if needs be.
Thanks.
Thanks.
