Hey,
I've always been a fan and just air-cooled all the way, however reading and seeing all these lovely water-cooled rigs and most of them using UV liquids, tubing or coils to make it look even more visually awesome just makes me want to get into the water-cooling side of computer cooling! I've been meaning too anyway, so I thought I would now..
My specs are in my sig, and I've researched a bit on water cooling, what you need, how it works, management, etc.. So I'm looking at cooling my CPU (Q6600), my GPU (HD4870) and I'm presuming it would be sensible to cool my motherboard's chipset as well? So that as well.
This is a project I'm planning for the summer by the way within the next 2/3 months, maybe less.
So far I've only spec'd myself the following:
Now I know I also need things like the coolant/fluids, tubing, coils, barbs, etc.. However other than the spec I've just listed, I'm not sure what else I will need to finish my list to have a complete WC kit so I can cool what I want.. Can anyone else help me finish my list off or modify it to something more suitable if what I have said isn't good enough..?
I want my first time doing this to be spot on and work first time round so I'd rather get some more experienced opinions and words of wisdom from people who have done this before and know what there talking about.
Cheers.
- £40.24 - CPU Block :: EK Supreme i7 Clear Top (Socket A,754,939,AM2,478,LGA775 & LGA1366) CPU Water Block
- £78.19 - GPU Block :: EK HD 4870 Acrylic Full Cover VGA Water Block
- £40.24 - Res/Pump :: XSPC Dual 750 Bay Reservoir & Pump - Clear
- £34.49 - Radiator :: XSPC RS360 120mm Radiator - Black
- £5.74 - Rad Fans (3x) :: Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin
I want my first time doing this to be spot on and work first time round so I'd rather get some more experienced opinions and words of wisdom from people who have done this before and know what there talking about.Cheers.
