- 3 May 2004
- Kapitalist Republik of Surrey
Following on from my spudmatic gun I'll move onto my jet scooter. I built a large-ish pulsejet as part of my final year project at university. It's made from mild steel pipe and rolled sections with a 2" exhaust. It runs on propane and output is about 15lbs of thrust I think, can't remember. Naturally with a jet in the shed you need a scooter to put it on so I lengthened one of those metal kick scooters and mounted the jet on the back. This is what I ended up with:
Note how there's no throttle and no brake. Power is controlled by winding in the regulator which is about 5 turns from off to 4 bar of gas pressure:
Noisy end where all the fire comes out:
Intake, sucks the hairs off your legs:
And as with most of my toys it folds up and neatly stashes in the corner
Here's a youtube video of some early testing. It's all the footage I have but the jumping camerman who starts to back off when I wind it up gives you an idea how loud it is!
Running procedure is sparkplug on, gas on, shoot some air in the front with a leaf blower to start it, turn the sparkplug off and wind the gas up. At the end you see a shower of sparks fly out the front and the motor stops. This is the valves destoying themselves before I had found suitable material for them and I experimented with a tuned valveless intake for indefinite running. Short video here:
How does it go? Well it makes a proper load of noise, glows red hot, there's fire, explosions and a real risk of getting hurt. It doesn't actually go all that fast because it doesn't have a huge amount of thrust for the weight of a person. I have ridden it and slipped off and when the weight is off the deck it tries to fly off. So consider this the mk1 and there's a mk2 in the pipeline with brakes, proper throttle control and somewhere better to stand. And a little more thrust of course
