£1100-£1300 i7 rig - few questions
31 Aug 2006
London
Hi all,
After nearly 2 years with my C2D rig I decided to ebay it and build a new one with i7. What psu do you recommend, preferably modular for say under £80? Ocz in my list is got bad reviews. Also should I P6T SE and save some money or any other good m/b? Also will the noctua be ok? Had one very similar on my C2D with no problems. Any other recommendations?
Product Name
Qty Price Line Total
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - OEM
£227.99
(£198.25) £227.99
(£198.25)
Asus P6T Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
£204.99
(£178.25) £204.99
(£178.25)
Gainward ATI Radeon HD 4870 Golden Sample 1024MB GDDR5 Dual DVI/HDMI (PCI-Express) - Retail
£140.99
(£122.60) £140.99
(£122.60)
OCZ 'FlexEX' 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Tri-Channel (OCZ3FXE1600C7LV6GK)
£114.99
(£99.99) £229.98
(£199.98)
Creative Sound Blaster X-Fi Titanium - Fatal1ty Professional Series 7.1 Sound Card (70SB088600000)
£105.00
(£91.30) £105.00
(£91.30)
OCZ ModXStream Pro 700w Silent SLI Ready ATX2 Modular Power Supply
£79.99
(£69.56) £79.99
(£69.56)
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM (ST31000528AS)
£78.99
(£68.69) £157.98
(£137.38)
Coolermaster Sileo 500 Silent Case - Black (NO PSU)
£66.99
(£58.25) £66.99
(£58.25)
Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366)
£57.99
(£50.43) £57.99
(£50.43)
LG GH22NS30 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
£18.99
(£16.51) £18.99
(£16.51)
Sub Total : £1,122.51
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.75
VAT is being charged at 15% VAT : £170.44
Total : £1,306.70
Im sure the noctua will be fine, do you really need 12 gig of RAM? I doubt it unless youre running virtual machines, 6 gig will do, aslo this stuff would save you a bit of money which you could use to upgrade other things, maybe get a 4870x2 if youre a gamer and using 24"+ screen
For £2 more you can get the retail CPU incl longer warranty, stock HSF (maybe use as a paperweight or something? lol) and Farcry2
thanks for the CPU idea...did not know the warranty is longer ? I was thinking if better ram makes different for overclocking... I am not an extreme overclocker just something standard and easy...maybe from 2.66 to 3 would be ok
have a look at the Titan TTC-NK85TZ Fenrir CPU cooler.
any 12800 memory will do tbh.
have a look at the Gigabyte GA-EX58-UD3R mobo.
maybe worth a look at the Asus Xonar D2 7.1 sound card.
agree with 95th about the retail cpu.
dont like the gigabyte m/b because of only 4 ram slots
not really worth 7.1 soundcard as I only use headphones
thanks, will get only 6gb ram for now and the cheaper one
