Hi all,
I am having a slight stability issue with my rig. Spec is:
Q6600 g0 @ 3.6Ghz
8GB OCZ Gold PC6400 @ 400Mhz (Divider 1:1) - Timings 6-6-6-18
Motherboard: Gigabyte GA-P35DS3R
BFG 280GTX OC
620Watt Enermax PSU
Basically, the problem is showing three symptoms:
1) When coming out of standby/sleep mode it switches back on, i.e fans are spinning and the hard drives fire into life, the monitor switches on but the display is black. After a short while the monitor power button starts blinking. If you press the reset button nothing happens. The only way to get it working again is to hold the power down and turn it off and on. Noticed this morning when it happened there was a Red light on the back of my graphics card??
2) When turning my pc on from cold it sometimes does the same as above.
3) Very occassionally it randomly reboot itself (No blue screen of death) just the monitor goes black and then the pc reboots.
Things I have tried:
- Memtest on individual sticks and also with all 4 dimm's loaded. I don't get any memory errors.
- Clocked my cpu back to 2.4ghz with stock settings across the board, still get the same issue
- Prime95 on all four cores for ten hours straight, no errors.
- I have played games such as cod4 and left4dead for several hours without issue.
- Ran 3d Mark Vantage no problems.
I am thinking maybe it is a motherboard problem? I didn't put any extra volts through my board before the problems started happening but I have since increased the mch by 0.1, this seemed to help for a while but then the problems returned.
I am not 100% sure but I believe my issues started happening when I replaced the graphics card and memory. This has been happening for quite a while now and I seem to remember when I checked the event viewer there was some graphics card related errors when it crashed - although I would need to check this to confirm (don't want to throw anyone off course).
All help appreciated.
Thanks,
Spooks
Q6600 g0 @ 3.6Ghz
BFG 280GTX OC
620Watt Enermax PSU
Thanks,
Spooks
