- 25 Nov 2002
- Somerset
Finally got my new machine all up and running.
i7 920 D0
EVGA Classified Mobo
12GB OCZ Blade RAM
3 x GTX 275 in Tri SLI
Baisc Water on the CPU Only
BeQuiet 1000w PSU
After much work I have established my 'suiside' and 'stable' overclocks.
suiside = 4.65Ghz, stable = 4.4Ghz
Now my question...
at 4.4Ghz 21x210 1.35v Vcore
These tests work perfectly and run without issue...
Prime
LinX
3DMark2006 29030
SuperPi
No when I come to Vantage the first graphics test is fine. The second test at frame 4800 ish I get a complete system crash - no BSOD just complete and instant power off. The PC will auto restart and windows does not report a bad shutdown or anything on re-boot
I have tried adjusting the voltages - without change
I have tried reducing the overclock - I only get success at stock or very near stock Bclk
I then tried switching off SLI - worked fine
Then I changed to 2 way SLI with the 3rd card sat passive and all was ok
So... I think I am suffereing from a PSU overload shutdown...and therefore need to either drop to 2 way SLI and a dedicated Physix card or get a 1200W Psu
Could I ask you guys what you think and for any suggestions.
Thanks in advance
i7 920 D0
12GB OCZ Blade RAM
BeQuiet 1000w PSU
Now my question...
Prime
LinX
3DMark2006 29030
SuperPi
Thanks in advance
