Installing windows XP on a machine running Vista
23 Nov 2004
Cambridgeshire
Will windows allow me to install a older operating system? If so what is the best way to do this?
Thanks
If you mean dual-booting, yes it can be done, but it's a bit fiddly - the XP bootloader will stamp all over the Vista version and then fail to recognise the existing Vista installation, so you'll have to reconfigure things manually.
There's a guide here which seems to explain it nicely.
Unless you need your full hardware capabilities under XP, it might be better to install it as a guest in a virtual machine. :)
Why anyone would go backwards in regards to operating system tech is beyond me.
Have 2 laptops in the house on Vista,also another pc on Vista but my media centre pc i would prefer to have on XP. The media pc i connect to work with as it uses a vpn client that Vista causes issues with.
