Also what TV cards are people using as mine dosent have 64 bit drivers![]()
I've got a Winfast Palmtop DTV200H (analogue+digital) it's an external USB one. Works flawlessly with Windows 7 RC 7100 64bit
when using virtual xp,do you need its own antivirus or is it still protected by whatever you have installed on windows 7 ?
If you go in to Tools, there is the option to restore the last browsing session which basically restores all the last tabs.
But that's a whole 2 clicks extra than firefox![]()
Heh all of which takes 5 seconds to do. I don't like to keep tabs open when I shut down the interweb. I always start a fresh everytime so this 'lack of feature' doesn't bother me.
I just had an emil saying the trial version expires on august 1st 2009 and from the 1st june 2009, the pc running it will shut down every 2 hours.
I thought this didnt expire till next year?
anyone else think the control panel is too confusing now?? I always look at classic view and now there are 54 icons! and only 2 of them are extras (vaio and bluetooth).
I'm using a Pinnacle 7010iX, with the x64 drivers from MS Update - these seem to work OK, unlike the previous Vista x64 drivers from MS (I had to use the BlackGold drivers instead).Those that are running tv cards, what software are you using with them? Also are you using an internal or external aerial?
