Q9550 on Asus Maximus SE failure
Caporegime
20 Jan 2005
Co Durham
Okay, I give up and I need help from the forums.
I don't consider myself a noob at overclocking after having my q6600 at 3.85Ghz on both my ABit ip35pro and my current Asus Maximus SE mobo but I have recently bought a Q9650 from this forum where both users have had it to 4.4Ghz with evidence
Now, I know my mobo can do 475 fsb since I had my q6600 at 8 x 475 stable. Looking at reviews these boards max out on the FSB at around 490 as well.
I know my memory can do 900 at 4-4-4-12 and 1080 at 5-5-5-18 since I have records of it running at that speed with my q6600.
But, although I have being reading around the net, I am struggling with my q9650 and Asus board and I would like to improve it.
Currently running prime stable at 4Ghz (small tft and blend) at the following settings:
9 x 444
vcore 1.23v
CPU PLL 1.3v
NB: 1.3v
Dram: 2.04v (the asus overvolts so this gives 2.11v to 2.12v in real life)
FSB Termination: 1.3v
SB: 1.1v
SB 1.5v: 1.5v
CPU GTL: 0.63x
Memory: 5-5-5-18
Load temps: 53C
Cpu and mobo watercooled so nb temps (43C) and cpu temps not an issue.
Now I know the x38 boards aren't the best overclockers but my q9650 ran at 4.4ghz on Asus Rampage x48 boards on this forum and the maximus isn't a million miles away from that. Is it worth swapping the bios to the rampage bios? Would I see any gain?
Anyway to the problem:
If I up the fsb to 445 it isn't stable in prime anymore. Even setting the memory to 6-6-6-18 makes no difference and upping the vcore right to 1.4v in steps made no difference.
If I set the multi to 6x it still isn't stable at 445 with mem at 6-6-6-18
Playing around last night I managed to get 6 x 450 stable with FSB of 1.8v and NB of 1.8v :eek:
I just kept upping both FSB and NB by one notch each to try and find max FSB. Is this correct? Should I be altering something else to get the fsb stable? SHould I just be altering the FSB voltage at all to find max fsb speed or just the NB voltage? Does CPU PLL have a bearing on fsb stability?
Okay, fsb hole I thought and I have tried both 460 and 470 and although it boots into windows, no stability as blend fails on core 3 within one minute.
And in general because I like to know these things, when should I alter SB and SB1.5v settings? What do these have an effect over?
It was much easier on the ABit IP35 pro to max out my q6600 as fewer settings so I am now a bit lost with the Maximus bios.
Should I be touching the ddr gtl settings? What about AI twister and all those other silly things?
Any help or pointing me in the right direction is greatly appreciated.
Okay, chances are I will settle of 4Ghz for day to day running since everything is at low volts and easy to run and keep cool but if I could get 4.2Ghz or more working at not much more I would quite like that for 24/7 use.
Oh, and my cpu only needed less than 1.3v vcore to run at 4.2Ghz from the preivous owners of it.
Thanks in advance for your help.
Buy a P45 board.
The x38-Q9xxx FSB isssue has been mentioned a good few times on this board, as recently as last week.
My Q9450 did 475mhz in my IP35 Pro, >500mhz in my P5Q Deluxe, but wouldn't exceed 450mhz in my Maximus Formula SE.
Your also running 8GB which would limit your maximum overclock. I'd try taking 4GB out and then re-clocking and see where you get to :)
Sorry dude.
But x38 only was and only ever will be for those that needed a pair of x16 PCI-E lanes and couldn't afford an x48 board. I sold mine after 2 weeks of banging my head against the (fsb) wall.
Sorry I should have said that my overclocking attempts have being done with only 2 ram chips present, not all 4.
Cob, what's the best p45 for q9xxx overclocking then?
Gigabyte EP45-UD3P OR R?
Both of these seem to be getting 500+ with q9650. Anybody know the difference between P and R?
Is this a good choice?
Cheers for that Happy, you are indeed right!
Before I click buy for £104, any other boards I should consider? Especially interested in people with q9xxx and high overclocks.
I will miss having my mobo watercooled and my optical out though.:(
Would a x48 board do as well or would that just be a sideways move? There are some cracking deals to be had on x48 boards atm.
I would say since the Gigabyte X48 is £99 is should be looked at, but since you didn't initially want to upgrade the mobo in the first place, I would get a P45 since it's much more likely to get a better clock. Just had a look on the site, and for another £11 just get the Tpower I45.
You's recommend the Tpower I45 over the Gigabyte EP45-UD3R? Similar money (in fact gigabyte slightly cheaper) and I have only researched the Gigabyte board so far and seems to be happy at 500+ with q9xxx.
I've just being reading through all 81 pages of the original owner of this cpu's thread on another forum and he hit a 460 fsb wall with his x38 mobo. Funnily ernough he also failed with the Asus p5q to get above 465 and it was only after getting a EP45-UD3P that he got the cpu to 4.4GHz.
Looks like to play it safe I am best getting a EP45-UD3P. I would hate to swap mobos just to find I can get another 100Mhz more.
On the other hand I'm not sure I can bothered tbh. I hate having to drain my watercooling loop and strip everything out and swap boards and make the cables all tidy again. Not sure its worth it for a 300-400Mhz gain just for that little bit of extra performance.
I'm thinking now that if I was going to go to all that hassle then a x58/i7/ddr3 combo would be the way to go. Should only cost me £70-£80 to swap it all, maybe less.
