Getting back into CS, all seeing eye no longer? What do i use to find servers?
22 Jul 2006
OK so wanting to get back into gaming, I cant seem to find ASE anywhere, what should I use to find servers, the steam one only ever brings up annoying french/german servers.
Thanks
Gamespy or the inbuilt browser is all I ever used....just filter to Europe and ping below <100 and things are usually good - although getting the odd FR or DE server does get annoying.
Thanks, will give gamespy a go. I never ever can seem to pick up UK servers using the CS, never have. Is there something in options you can do to set default country being UK?
Yes, just use Steam server browser. I think you can default to Europe, not UK, but just do that and look for servers with "UK" in the name. There are thousands!
