very high is not ultra high ^
Min Max Avg
14 50 30.05
A deep wallet.crysis, what do you need to play on ultra with good fps
SIZE="1"]26/05/2009 02:54:07 - Vista 64
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1900x1200, AA=4x, Vsync=Disabled, 64 bit test, FullScreen
Demo Loops=5, Time Of Day= 8
Global Game Quality: VeryHigh
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 40.40s, Average FPS: 49.51
Min FPS: 35.55 at frame 1941, Max FPS: 69.21 at frame 992
Average Tri/Sec: -30655514, Tri/Frame: -619218
Recorded/Played Tris ratio: -1.48
!TimeDemo Run 1 Finished.
Play Time: 38.12s, Average FPS: 52.47
Min FPS: 34.76 at frame 1945, Max FPS: 70.58 at frame 1008
Average Tri/Sec: -32401970, Tri/Frame: -617515
!TimeDemo Run 2 Finished.
Play Time: 38.08s, Average FPS: 52.53
Min FPS: 34.19 at frame 1951, Max FPS: 70.58 at frame 1008
Average Tri/Sec: -32403638, Tri/Frame: -616891
Recorded/Played Tris ratio: -1.49
!TimeDemo Run 3 Finished.
Play Time: 37.89s, Average FPS: 52.79
Min FPS: 32.96 at frame 1958, Max FPS: 70.58 at frame 1008
Average Tri/Sec: -32653568, Tri/Frame: -618545
!TimeDemo Run 4 Finished.
Play Time: 37.94s, Average FPS: 52.71
Min FPS: 32.96 at frame 1958, Max FPS: 71.98 at frame 74
Average Tri/Sec: -32615278, Tri/Frame: -618778
TimeDemo Play Ended, (5 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1900x1200 AA=4x, 64 bit test, Quality: VeryHigh ~~ Overall Average FPS: 52.625
a gtx 295, sli 260, 280 or 285. When i tried the 4870x2 10 days ago it was 2 fps slower than my old gtx 280.
FPS results while you are staring at walls in areas with very little light isn't exactly a great representation, unless you are trying to show maximum FPS and not average.
