Everyone was saying that about 18 months agoWhat do you need to play crysis on ultra with high FPS ?
A time machine , go about 1 year into the future and the hardware available then might be able to run it
Everyone was saying that about 18 months ago![]()
It probably still causes the lowest frame rates which would imply it is still the most challenging!
That won't run it either, why no one mentioned it in here![]()
. I was going to suggest that two of them might have an outside shot, though with the physical and driver-related hindrances associated with quad, you'd probably find that three heavily OC'd 285s would turn in a better result.
Wha???!! Am I the only one here who went from a 4870X2 -> GTX285 and noticed my performance go UP? The 4870X2 was all over the place in terms of consistent FPS. The GTX285 just eats up Crysis. Maybe my rig wasnt beasty enough to handle the X2 or summit? Although, one would have thought that 4.40Ghz E8400 could handle it...
hehe, i play it at 2560 al very high in dx10 under vista 64 and get decent (40ish being minimum except for random spikes because of quad SLI) fps, but thats using 8x asf and no aa. AA KILLS my performance which im guessing is because of the memory limitations running at that res and settings, either that or the drivers i was using at the time. This was tested ages ago when i first got my quad setup though, and ive tweaked the hell out of it now so i probably can get a decent amount more out of it now. would help if i turned on the optimizations and put settings to optimal instead of quality etc but i cba since i dont play the game hardly ever.
edit this is from memory during gameplay when i lookeda t my fps, so numbers might be off)
280 SLI at the very minimum, for total maxing.
I can play fairly comfortably at 1920x1200 Very High DX10 2x AA but at times you can really feel it slooooowing down.
)I wonder if i was to whack a 9600GT iin there as a physix card, would i offload some of the pressure and up the FPS?
