quietest 120m fans on paper?
any fan you want as long as it's not moving :)
Depends on what you want it for quiet isnt necessarily good if its for a case then it will be different than for a heatsink as static pressure comes into play and if you use a good fan controller they are all quiet even the deltas :)
Most fans can be made next to silent by voltmodding them to 7v or 5v, just choose a good set to begin with that can work at that low voltage.
I've always found noctua fans to be very quiet unless they have a lot of mesh or similar near them, which causes turbulence.
