Pahncrd's Oblivion Enhanced Edition ( 12GB+!! )
Looks like there is a problem with the omods... it may run right away if installed in d:\games\oblivion.
Honestly, the current version will require a bit of work to get running, but the bugged fixed should be better.
Who knew that complex things can go wrong. :confused:
With any luck we will have it figured out very soon, so all you slavering oblivion monkeys can get at it.
Is it done yet!!!
Looks like if you reload the omods and download suprememagicka omod and intsall that too, then run boss.exe in the data folder, everything works fine. The problem is that the omods are spread around the oblivion install.
Also, must not install MEAT .omod
There should be 10 omods in all.
3) Copy everything from the enhanced edition into the Oblivion directory on your hard drive.
After this make sure you run oblivion launcher , do not run the game itself then just quit. As it will create the ini file needed for STEP 4 ;).
I tink its your fault for using silly newsgroups and not torrenting so the world could help bug fix and not the snobby people wid more dosh!
Of course its just my opinion, but im always right...
Probably true... :( We are getting close though.
Original thread:http://www.rage3d.com/board/showthread.php?t=33946273
This is an Oblivion version with a set of painstakingly selected modifications, tweaks and changes to provide the
most interesting and fun Oblivion experience possible. This is a complete modification of all parts, but nothing
cheesy or unbalanced. In fact, the difficulty curve should be steeper and more enjoyable. There is no aspect of
the game that has not been improved or fixed from vanilla Oblivion. This will give a chance for people to play it,
that never wanted to spend the days needed to properly set up an Enhanced Oblivion Installation.
Installation:
1) Install Oblivion, but don't worry about expansions, updates or anything else.
2) Run oblivion one time and then exit. Delete everything in the base Oblivion directory so that nothing remains.
enhanced edition.
4) finding the omods - use Oblivion Mod Manager to load the following omods;
1. Eve_for_Francesco_Version_1_4-24078
2. EVE_for_MartigenMonsterMod-24078
3. EVE_for_Oscuros_Oblivion_Overhaul_1_3-24078
4. EVE_HGEC_BodyStockandClothing-24078
5. Female EyeCandy - Body Replacer (nude) 1.0
6. Full_Landscape_LOD_Textures_Replacement_v1.0_OMOD
7. GMs_Deadly_Oblivion_Overhaul_Lite_1_2_omod-24322
8. Unique Landscapes Compilation 1.4.2
Which are all located in oblivion-> obmm -> omod
Then load the following omods
1. DarNified UI 1.3.2
Which is located in the oblivion-> data folder
Then download and load "supreme magicka" located here
http://www.tesnexus.com/downloads/file.php?id=10791
- use obmm to create an omod by opening obmm and hitting the create button, then add folder, and pick the supreme magicka folder. It will ask if you want to use the conversion data, you need to say yes.... then it will convert it into an omod.
-activate all supreme magicaka options except for "cobl" when it asks.
Be sure not to load any other omods you might find.
5) Now to activate the omods- activate hgec first and choose normal h cup graity upper body and normal lower body.
Now you can install everything else in the order that you want.
- do not install the body textures when EVE_* .omod asks if you want to.
Activate all other esps.
6) Run boss.exe located in the data directory.
7)Because of a small oversight on my part (to go along with the many others :( ), you will need to uninstall the PC
voice, if playing a female character, unless the character is a post op transexual.
1. Start Oblivion Launcher, click Data Files, uncheck the .esp file PCSoundKensai.esp.
2. Delete the files/folders associated with the mod.
Oblivion\Data\PCSoundKensai.esp
Oblivion\Data\Sound\Voice\PCSoundSet\Kensai\
Oblivion\Data\Sound\Fx\PCSoundKensai.esp\
Oblivion\Data\Meshes\PCSound\
Oblivion\Data\Meshes\Characters\_male\Idleanims\PCSound\
Go here.. http://www.tesnexus.com/downloads/file.php?id=12588 to pick out a voice that you would like to use if you
want to.
8) Run the game with obse_loader.exe, which is located in the Oblivion directory on your HDD now.You must start the
game with this file from now until you delete the game.
9) It is important that the first time you run the game that you set up your leveling system by casting "alter
destiny" which should be available now in your spell/power list. The manual for the leveling system is here...
http://www.irisgames.com/KCAS/KCAS Manual.html
10) Also, the first time you run the game, you should look in your inventory for Deadly Reflex Reset, as it will
allow you to change the hotkeys for your special moves such as bash, kick and dodge. Otherwise it will default to
"R" for bash, "Q" for dodge and "Z" will remain as grab/kick. Deadly Reflex will automatically start asking you
about buttons if you are starting a new character.
Everything else should be pre-configured if I have done everything correctly, and will not require any changes from
the user. Your saved games and general settings will not be effected, as that stuff is located within your
Documents folder. Hopefully everything works as it is supposed to, but as with everything your mileage may vary.
All rights and credit for all modifications remains with their original authors.
There may be the occasional small bug, but I have not encountered anything that I would call a showstopper or even
annoying. Hopefully your luck is as good as mine.
You can always add your own mods, but you should activate the mod in oblivion mod manager, then run BOSS.exe
(located in the data folder)to put the mod in the correct load order, then rebuild the bashed patch, and everything
should be cool.
If you do not have a Deadly Reflex reset item, or an altered destiny, then download and install the following and
run Boss.exe in the data folder.
http://www.tesnexus.com/downloads/file.php?id=1888
http://www.tesnexus.com/downloads/file.php?id=8273
Note: The leveling mod doesn't show up until you exit the first dungeon.
Hopefully this gets us humming, though it is a few more steps than I was hoping for... the bug fixed version should help with that.
Streamline it bud, get us a working version minus god knows how many pages of forum searches to get it working before you release it :/
Or at least insert (beta) into your titles.
:o Yeah, lesson learned.
The bug fixed version will probably start uploading tonight.
