I may be wrong but I thought the cold side had to have a 'load' e.g. a hot processor or they are uneffective/fail? Sounds interesting though
7c is a load, it has heat, a pelt say can reduce water temp by 20C for example, doesn't matter if its cooling something 70c down to 50c, or 10c down to -10C.
The problem however is a 140W pelt ISN'T remotely close to enough. hell, 140W would be the bare minimum I'd put on something like a 280gtx.
You have to remove the cpu heatload AND the heat the pelt creates. In reality you need something MASSIVELY more powerful than the thing you're cooling to do so effectively. IE a 100W cpu(overclocked 150W or more easily when overvolted) you'd want at a bare minimum a 227W pelt, maybe quite a bit more. People used to use 227W ones on single core older cpu's, not massively lower loads to be honest, but a quad core under full load, not sure a 227 would cut it.
This is ignoring the fact most pelts are rated at 14v, at 12v you get a pretty decent drop in capacity, you can use a bigger pelt and run undervolted at 12v, but even then its a massive single load to put on a single line on your psu which will be under constant heavy load. 18amps is what most single rail's on psu's will run at, which is barely capable of running a 227W pelt on its own.
So most people are buying something like a meanwell(last i looked years ago) dedicated variable voltage psu, talking something like £100 for a high quality psu just for the pelt, which will set you back £40, which will consistantly require 250W of power from the wall to run all day every day regardless of cpu load.
IN other words, they cost a bomb, cost a lot to run, are inefficient, a pain to set up and frankly won't give you a "huge" drop in temps/increase in overclock compared to plain watercooling.
Also need to cool the pelt evenly rather than the more direct/concentrated cpu waterblocks that tend to focus removing heat from the centre of the cpu, and not many waterblock makers focusing on pelt blocks anymore(if any?).
In other words, simply not worth it anymore.
About the most I'd bother with these days, is a 80-120w pelt on a gpu, even thats just really not worth it these days. For the price of pelt, cost to run, cost to insulate and voiding warranty by covering the pcb in grease, buy a 2nd gfx card.
