lens
umm if its anything like my old S5000 then its fixed lens? you can get whacking great teleconverters though if i remember rightly. the 1.4x was the better quality one.
How old are you?
16
I am sure I can as on the camera they is a bit on the lens that is all ready on what look's like where you can scew something on to it like a other lens
You can attach those cheap plastic lens infront of your fixed lens from the bay, relatively cheap but not very good quality. They come in handy for Macro shots - telephoto lens of that kind are poor if anything really.
Plus, you'll need dead steady hands or a tripod to make full use of it at full tele or you'll risk camera shake.
Fuji produce wide and tele lens converters which attach to the screw fit on the lens.
I expect they'll cause a drop in IQ though.
