- 11 Sep 2008
- Northern Ireland
I put Vista to sleep, and as soon as it went into sleep mode, it woke itself up and now I have a black screen. My keyboard and mouse don't work. When I googled it, other people had the problem but they never posted how to get vista working again
Here's what goes wrong: you push the power button in the Start menu – this is by default configured to use the Sleep mode. Sometimes this works ok, other times you get a black screen, some USB-peripherals are correctly disabled but the machine itself doesn't power off (fans keep turning etc.). To make matters worse, you can't wake your pc because your USB keyboard has already been disabled.
It also occurs that while your machine apparently went to sleep without problems, it won't start up again or even if it does, it hangs on a black screen and you can't do anything to go further.
Does anyone have any ideas? Turning it off didn't help.
