Basically I have a massive bucket that I am pretty confident my whole computer could fit into, so is it just a matter of removing everything and placing the case inside the bucket to help with spillage.
Then get a pyrex jug and then place this under the cpu block, cut the tube and everything will gush out?
As the coolant is less than 6 months old I would like to keep it, the main reason of re-design is to get rid of a kink that has appeared!
Thanks!
Thanks!
