New car - Bargain of the year ??
How does it drive? I ask as a mate of mine got a 51 Plate one of these for £450, it turned out to be a rather shagged out ex-taxi.
Either way, £400 is a bargain assuming its not a ringer!
Drives fine , Nice and easy to drive to be honest .
Found the engine and its not inflatable either :p
Couple pictures of the paint work close up aswell to show you the state of it .
Roof
Bonnet
Covered in scratches like this which is not a problem
whoa, absolute bargain. Hopefully there's nothing nasty lurking around the car.
*Goes on the hunt for a £3k e46 M3*
Does anyone have any idea what these are ? It does have an old nokia hands free kit installed and maybe they are both to do with that but I have no idea
Black hole next to the hazard switch
Little box in glove box that when a button is pressed a light flashes in top middle
That keypad is aftermarket imobaliser, you can use it if you loose the fob and program new keys. (You can with some Sigma alarms) there should be a 4 number pin code with the alarm documents
The socket could be for the Nokia hands-free kit you mentioned I suppose, seems likely anyway.
My Mondeo has a 3.5mm auxiliary socket for the stereo in the glove box, so you can connect an mp3 player or something, I don't know if the pre facelift Mk3's have them or not, I guess it could possibly just be an auxiliary socket if it's not for the phone. Although the location seems very odd if it is.
The hands free kit had a cradle for the phone , I tried plugging in a 3.5mm plug but the plug was to small so maybe a 5mm as if it was put in when the car was new in 2001 maybe they used those more then .
I managed to sort a few niggles out like the 12v input wasnt working and the glove box light was not working either .
