This is an Oblivion version with a set of painstakingly selected modifications, tweaks and changes to provide the most interesting and fun Oblivion experience possible. This is a complete modification of all parts, but nothing cheesy or unbalanced. In fact, the difficulty curve should be steeper and more enjoyable. There is no aspect of the game that has not been improved or fixed from vanilla Oblivion. This will give a chance for people to play it, that never wanted to spend the days needed to properly set up an Enhanced Oblivion Installation.
Oblivion Enhanced Edition Beta_01_patch
Original thread:
http://www.rage3d.com/board/showthread.php?t=33946273
Installation:
1) Install Oblivion, but don't worry about expansions, updates or anything else.
2) Run oblivion one time, set the video settings the way you want and then exit. Delete everything in the base Oblivion directory so that nothing remains.
3) Copy everything from the beta_01 enhanced edition into the Oblivion directory on your hard drive.
4) delete the "obmm" directory located in the Oblivion folder then copy the patch contents into the oblivion folder immediately after, be sure to overwrite.
5) Run Oblivion Mod Manager to make sure that you have 10 omods in the right hand box and that they are all blue, and close without touching anything.
6) Run removevoice.bat, which is located in the patch, from the oblivion directory. (it should be in there by default).
7) Run the game with obse_loader.exe, which is located in the Oblivion directory on your HDD now.You must start the game with this file from now until you delete the game.
8) It is important that the first time you run the game that you set up your leveling system by casting "alter destiny" which should be available now in your spell/power list. The manual for the leveling system is here...
http://www.irisgames.com/KCAS/KCAS Manual.html
9) Also, the first time you run the game, you should look in your inventory for Deadly Reflex Reset, as it will allow you to change the hotkeys for your special moves such as bash, kick and dodge. Otherwise it will default to "R" for bash, "Q" for dodge and "Z" will remain as grab/kick. Deadly Reflex will automatically start asking you about buttons if you are starting a new character. Everything else should be pre-configured if I have done everything correctly, and will not require any changes from the user. Your saved games and general settings will not be effected, as that stuff is located within your Documents folder. Hopefully everything works as it is supposed to, but as with everything your mileage may vary. All rights and credit for all modifications remains with their original authors. There may be the occasional small bug, but I have not encountered anything that I would call a showstopper or even annoying. Hopefully your luck is as good as mine. You can always add your own mods, but you should activate the mod in oblivion mod manager, then run BOSS.exe (located in the data folder)to put the mod in the correct load order, then rebuild the bashed patch, and everything should be cool.
If you do not have a Deadly Reflex reset item, or an altered destiny, then download and install the following and
run Boss.exe in the data folder.
http://www.tesnexus.com/downloads/file.php?id=1888
http://www.tesnexus.com/downloads/file.php?id=8273
Note: The leveling mod doesn't show up until you exit the first dungeon..
IF YOU GET ANY MICROSTUTTER / STUTTER OR FRAMESKIP TRY THIS FIX
http://forums.overclockers.co.uk/sho...php?t=18014698
