Just curious to see how many folks temps have jumped a bit with all this fantastic weather we are having at the moment?.
My C2D E6300 @ 3.2Ghz with an Arctic Freezer 7 Pro usually sits at around the 40-44 deg mark during normal usage/web browsing but over the past few days its jumped up a bit to around 48 deg. Probably due to the ambient room temp being higher because of the sun streaming through the windows?!!.
Anyone else noticed a jump in temps?.
Yes I would say that my i7 at idle has gone from 38/40 degrees up to 42/44 - so a fairly good jump there! Gonna have to keep an eye on load temps as I don't really want to break through 80 degrees!
Mine are up about 3-4C, however when running at 100% CPU and GPU load all the time, even that can make a huge difference to overall temps and the room temp :/
It's less the effect of the ambient on the PC and more the effect of the PC on the ambient! System seems to be holding up so far - quad at 60/59/54/55 and GPU at 56 - so I'm folding on
YepIt's less the effect of the ambient on the PC and more the effect of the PC on the ambient!
