Am I entitled to a refund?
  • Thread starter Thread starter box
  • Start date Start date
box
box
20 Nov 2005
Bristol
I purchased an iPod adapter for my car in December from an online retailer for around £80. The product is covered by a 1 year warranty. Last week, the adapter began malfunctioning. I confirmed it was broken by replacing it with a friend's identical unit.
I have been in contact with the retailer/manufacturer, who are saying that they can only offer me a replacement product. Having decided that the product's quality isn't great to say the least, I would prefer a refund. Am I entitled to one, or do warranties only cover for direct replacement?
Thanks
Only the T&C disclaimer on the purchase slip can tell you, but more than likely no. Typically refunds have to be claimed within 10 days of purchase.
you'll only be covered for warranty replacement. Refund is not an option after this amount of time. your lucky they offered you a replacement..my mate had exact same issue and they declined ti help saying it was wear and tear...
No, they will more then likely refer you to the manufacturer who will only offer repair or replacement, it's a little late to be asking for the refund from the retailer.
If it has a fault deal with the manufacturer, they should help you out if it's under warranty
Well I guess that answers that then! Thanks guys.
Will stick the replacement on the bay methinks. Anyone looking for a VW XcarLink? ;)
Electronic wear and tear?! :D
Refund is indeed an option, at their discretion, under the Sales of Goods Act. I managed to get a refund on an Acer monitor after 2 years by proving it must have been a manufacturing defect causing a constant problem with the unit.
Within 6 months the onus is on the retailer to prove that the item wasn't poorly manufactured from day 1, after that it's on you.
