Over, or you might get poo on the wall.
....you're doing it wrong.
Over, with the end folded into a neat little point like in hotels![]()
Do you watch musicals while on the toilet as well?
Fold eh? Sophisticated, I use the yank and scrunch method.
Maybe sophisticated. I counter this by always buying the ultimate cheapest bog roll I can find, on the basis that "I'm only going to wipe my arse with it and flush it seconds later".
Anyway, it has to be over if you use the yank method, as the yank method relies on the friction between the sheet on top and the roll in order for the yank to work in the first place. Try doing the yank with an under and the full roll will simply spill onto the floor.
I have a wooden stick thing that my bog roll sits on so side on.
Are you applying physics to bog roll technique? Well done.
