Forget using the mobile connect software, just create a new dialup connection and put the number as *99#.
Thats what I have done, except Windows 7 never remembers the username and password for the connection.
Just downloaded 7100, having never used Vista or tried any of the betas I'm loving it so far, pretty much everything worked straight after install, all I needed was a driver for my HDMI capture card and the latest Nvidia drivers.
Is anyone using any virtual drive programs like Daemon tools? Since I installed this and it says it doesn't work properly, my system has been taking longer than before to boot.
1) I assume WLM is gone from the tray area? When I close it it just persists on the taskbar, which is okay but not what i'm used to.
It just isn't 100% compatible yet. You can get around it by browsing into the Live Messenger program directory and setting the msnmsgr.exe to run in Vista compatibility mode.
How do you know its not by design that it doesnt use the tray?
Windows 7 build 7201.0.090601-1516 is out.
I am just getting it to see whats new(if anything)
Rumored this is the last build before RTM....Anyone know?
use virtual clone drive
daemon tools is a joke
what would a virtual drive be used for?
RC2 build 7201 has now been leaked!
